5 members (DoubleB, EchoBravoSierra, frogfarmer, TooMany2count, Achipmunk), 55 guests, and 1 robot.
Topics128,090
Posts1,056,024
Members48,432
Does anyone know if the the 396 will bolt to the stock 3speed saginaw? What about the cluth fork? Are they different? Ive heard the motor mounts are the same? Anyone done a big block conversion? Ive got the 230ci in the truck now. Also...short of removing the the cover on the rear diff...I've got the stock 12bolt is it a posi?
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
A 396 should bolt up fine, but you may want to consider a trans with a bit more guts if you're going to run a big block. Not 100% sure if those mounts will work, but the chassis is similar to the '67-'72 which did have a bog block option, so setup should be the same.
For the diff, look for a tag the says "Limited Slip Fluid Only". Or, if no tag, jack the truck up and set the axle on the stands with the trasn in neutral. Try spining a tire by hand. If the turn in opposite directions, it's not a posi. A note if it is a Posi, parts might be hard to get, as the '63 is the early version of the 12 bolt with the 17 spline axle. From what I understand, the clutch packs are not being produced for that alxe, 30 spline (mid-'65-'76) only.
Bill Burmeister
Which trans would you recremend? I want to keep the coloumn shift. I've heard that there was a hd 3sp in the late sixties. Would the linkages work?
The HD trans was a Borg-Warner. Should work just fine as long as you get the shift arms that go with it.
Bill Burmeister
How about exhaust clearance for this swap? Are there any issues with frame clearance? I believe these frames are narrower than later model trucks. I was thinking of putting a big block in my 64 4x4.
Will the big block except the same cluth fork and assembly as the inline 6?
