| | | Forums66 Topics128,052 Posts1,055,729 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#60073 05/05/2006 1:41 AM | Joined: Apr 2006 Posts: 41 New Guy | | New Guy Joined: Apr 2006 Posts: 41 | Ok guys which is it adaptor plate or modified bellhousing? When I call to order a bellhousing they tell me I need an adaptor plate! When I order an adaptor plate I am told I need a bellhousing. I am swaping a saginaw into my 46 chevy 1/2 ton. | | |
#60074 05/05/2006 2:54 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I don't know...
My trucks are all later and use a different bellhousing than your '46. I'd wonder if you could swap to the '48 to '53 bellhousing to make this swap.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#60075 05/05/2006 3:03 AM | Joined: Apr 2006 Posts: 41 New Guy | | New Guy Joined: Apr 2006 Posts: 41 | I am sure I can but, to remove the bellhousing I have to remove the flywheel and probably the engine. When I called buffalo to order an adapter plate the guy said I need a bellhousing the plate won't work. I am confuse. | | |
#60076 05/05/2006 3:58 AM | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | I put a Saginaw in my '42 PU with a '60 235...it bolts right up to your stock bell housing.(either 216 or 235). | | |
#60077 05/05/2006 4:03 AM | Joined: Apr 2006 Posts: 41 New Guy | | New Guy Joined: Apr 2006 Posts: 41 | I have a 235 but, the truck still has the original bellhousing. Bolt holes don't line up. | | |
#60078 05/05/2006 5:08 AM | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Well, Buffalo (Steve) is the guy who modifies the 47 and later bellhousings to use your existing pedals in an early truck (36-46) and the fellow who makes the adapter plates. Call him again and ask him why you can't use an adapter plate rather than modifying a bellhousing. I would guess the input shaft isn't long enough to use an adapter. If that's the case you need a 47 and later bellhousing to send him to modify if you want to use your original pedals. | | |
#60079 05/05/2006 2:28 PM | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | Call Buffalo again. He talked me out of a bellhousing and into the adapter plate. I talked to him last week and he was building a bunch of adapter plates for people. You need to ask him why an adapter plate won't work for you.
You do not have to remove the engine to remove the bellhousing, but you do have to remove the flywheel.
John46, I thought you had already ordered the bellhousing from Jim Carter?
steveg, you got some pics of that saginaw bolted up to the stock 42 bellhousing? I don't see any way it would bolt up. | | |
#60080 05/05/2006 3:29 PM | Joined: Apr 2006 Posts: 41 New Guy | | New Guy Joined: Apr 2006 Posts: 41 | It was on back order so I ordered it from Buffalo. I called to order the adaptor plate he said I need the bellhousing. I will call again. Thanks | | |
