9 members (dt235sd, Gdads51, Gib70, 3B, Phak1, 32Fordpuchoptop, 68ironhead, Jon G, 2-Ton), 79 guests, and 0 robots.
Topics128,049
Posts1,055,693
#60073 05/05/2006 1:41 AM
Ok guys which is it adaptor plate or modified bellhousing? When I call to order a bellhousing they tell me I need an adaptor plate! When I order an adaptor plate I am told I need a bellhousing. I am swaping a saginaw into my 46 chevy 1/2 ton.
#60074 05/05/2006 2:54 AM
I don't know...
My trucks are all later and use a different bellhousing than your '46. I'd wonder if you could swap to the '48 to '53 bellhousing to make this swap.
#60075 05/05/2006 3:03 AM
I am sure I can but, to remove the bellhousing I have to remove the flywheel and probably the engine. When I called buffalo to order an adapter plate the guy said I need a bellhousing the plate won't work. I am confuse.
#60076 05/05/2006 3:58 AM
I put a Saginaw in my '42 PU with a '60 235...it bolts right up to your stock bell housing.(either 216 or 235).
Steve G.
1942 Chevrolet 1/2-Ton Pickup Truck
#60077 05/05/2006 4:03 AM
I have a 235 but, the truck still has the original bellhousing. Bolt holes don't line up.
#60078 05/05/2006 5:08 AM
Well, Buffalo (Steve) is the guy who modifies the 47 and later bellhousings to use your existing pedals in an early truck (36-46) and the fellow who makes the adapter plates. Call him again and ask him why you can't use an adapter plate rather than modifying a bellhousing. I would guess the input shaft isn't long enough to use an adapter. If that's the case you need a 47 and later bellhousing to send him to modify if you want to use your original pedals.
#60079 05/05/2006 2:28 PM
Call Buffalo again. He talked me out of a bellhousing and into the adapter plate. I talked to him last week and he was building a bunch of adapter plates for people. You need to ask him why an adapter plate won't work for you.
You do not have to remove the engine to remove the bellhousing, but you do have to remove the flywheel.
John46, I thought you had already ordered the bellhousing from Jim Carter?
steveg, you got some pics of that saginaw bolted up to the stock 42 bellhousing? I don't see any way it would bolt up.
#60080 05/05/2006 3:29 PM
It was on back order so I ordered it from Buffalo. I called to order the adaptor plate he said I need the bellhousing. I will call again.
