5 members (Gdads51, 52Carl, Woodcmiami, Gib70, 1 invisible), 80 guests, and 3 robots.
Topics128,060
Posts1,055,840
Members48,427
#600371 12/11/2009 11:09 PM
OOPs! I didn't save whatever attached the seal to the floor nor,OOPs #2, do I have any pics or notes. Is the seal attached with a couple of screws or smallish bolts? Thanks for any help.
Drew
Should be screws. 3 of them, if it's anything like the TF trucks.
Bill Burmeister
Ex Hall Monitor
Ex Hall Monitor
The seal on my 38 is held in place by gravity.
Another case of we're supposed to know what truck each of the 22,000 plus members has without being told.
Drew if you are referring to a AD truck 47 to 54 the floor seal attaches to the floor with 3 long screws that screw through the toe pan. "regards" John.
It's fun to drive and to work on. How much better can it get
Ouch Cletis, but you are right. cry My bad.
It's in the 47-54 AD class as suggested. It's mentioned as having three screws, but the seal from JC only has two premade holes positioned each side of the column and the firewall itself only has two holes. No matter.Screws it is.Thanks all. smile
Drew
Gotta play Sherlock Holmes sometimes Charlie, since Drew’s given us that it’s a 216 in his profile, I would assume its an AD. Hey Drew, you could update your profile now that you’ve gotten to know us.
Two large 1/4” Phillips head sheet metal screws hold them in place.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
For what it is worth, when I redid my steering column a couple of years ago if you had a 3 speed there were two different types of seals for the 47 to 54 trucks. It may be that the war era trucks were slightly different. My 52 is a war era truck so some things are slightly different. The column seal is a rubber covered plate with a backing. It seems that it is held in place with three screws, but don't hold me to that. The seal is an elipse that is bent at an angle in the lower 1/3 to match the firewall. I also had to wait untill I redid the steering box to install the seal, as I had to disconnect everything to work on it. As it turned out I had to drop the steering column from the dash, and the frame to get that &^%(*& seal on over the column.
We thought you were good enough to read minds.
