5 members (Hotrod Lincoln, Gray_Ghost, 78buckshot, Pete O, 1 invisible), 309 guests, and 6 robots.
Topics128,156
Posts1,057,021
Members48,460
ok i guess i need some help on how i go about wiring an alternater into my truck. trying to get an order set off to get my parts for converting to 12 volts so i can get this thing on the road.
Blue,
You didn't say if you already had an alternator, but I purchased a single wire alternater.
One wire from alternater to Battery side of starter, done.
Other alternaters can be converted to this.
Dennis
just-a-hacker
'49 3100 before '99
no i don't have an alternator yet. trying to figure out if i want to go that route. dont' plan on running a lot of extra stuff. heck i don't even have a radio in it. my uncle had a 47 and he ran a radio but no extras just the heater/defrost and wipers not sure if the wipers were vacume or not and all on 6 volt. to me a generator is simple and i can rebuilt it.
I run a 63 amp alternator,with internal regulator.You can rebuild them ,very easy to do.If you are running a wide belt,you will need a different pulley.Speedway motors sell these pulleys.
1951 3100 Chevrolet
I bought Alternator and mount brackets for 58 235 from Patricks, it works like a charm and happy with it
Ganesh
The shop I got the alternator from had a wide pulley in stock
just-a-hacker
'49 3100 before '99
