| | | Forums66 Topics128,076 Posts1,056,009 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#59996 05/04/2006 12:29 AM | Joined: Apr 2006 Posts: 38 Apprentice | | Apprentice Joined: Apr 2006 Posts: 38 | Hi, Nick here, I am swapping in a 350 SBC and am getting ready to start it. The 350 I have is TBI (fuel injected, kinda). I have taken a complete wiring harness out of the truck it came in and am wondering if any body has any advice...
Thanks | | |
#59997 05/04/2006 4:23 AM | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | I have lots of advice and even some related to your swap. Do a search on TBI in the archives first as I have covered this once before and then fire some questions at me.
Is this going in your '53 6500? Do you have the V8 bellhousing mounted yet? Are you using a tube mount for the V8? What year and model vehicle is your TBI 5.7 out of? What is your budget versus time frame to complete this swap? | | |
#59998 05/06/2006 3:48 PM | Joined: Apr 2006 Posts: 38 Apprentice | | Apprentice Joined: Apr 2006 Posts: 38 | Answers to your questions...
Yes its going in my 6500, I don't have the bell housing mounted yet, but soon, What's a tube mount???
K1500, 1989 was the donor truck
My budget is fine and my time frame is long, not in much of a hurry..
Thanks Nick | | |
#59999 05/06/2006 8:12 PM | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | If you've got the money, buy the painless performance wiring harness. If not, the harness out of an 87-91 van is much easier to work with than the truck harness. You will need a speed sending unit for the fuel injection to work correctly.
A tube mount is just that, it is a tube bent with v8 mounts on it that is easy to put in your frame. Some people use a front horseshoe or U type mount.
You must support the bellhousing from the sides as the SM420 was not available with a tailhousing mount like the SM465 was. How do you plan to mount the bellhousing? Do you have something fabricated already? A circle track mount with two biscuits works nicely. | | |
