4 members (Hotrod Lincoln, artinva, Bill Hanlon, Opelika Tom), 67 guests, and 2 robots.
Topics128,077
Posts1,055,932
Members48,430
#599709 12/09/2009 4:43 PM
I'm the proud owner of a 1954 chevy 3100. I got it 2 nights ago in KC MO before the bad weather hit. I will try to get some pictures on here when I figure out how.
I'm wanting to convert to 12 volt and not sure where to start. I want to keep the foot starter. My wiper motor isn't working so thinking about switching to 12 electrical. The defrost bearly got me home so planning on installing a heater and defroster assembly in 12 volt. Speedo and odometer don't work. get rebuild?? This is going to be an everyday driver pulling a small trailer hauling carpet for installing. My ranger's tranny or clutch is about to crap out on me. So I was hoping some of you guys could help me out.
Riding in the Passing Lane
The starter will be fine. Get an alt. & bracket kit. Put a Runtz resister on the fuel gauge. Change all the bulbs to 12 v. You already solved the wiper & heater part. That's about it but its pretty general. If you need help with the alt. circuit put another post in. A lot of people use the 1 wire alt for simplicity, but I still like the 3 wire w/int. reg. Don't get a high powered alt. About 55-65 amp tops. You can still use your original amp. meter with it. Besides the belt won't pull any more then that.
We are lucky here in K.C. area. We have 3 of the best parts places here in town.
1972 Chevy c10 Cheyenne Super
Congrats on the "new" truck and welcome to the 'bolt!
Just click on the techtips link at the top of the page here and look for the step-by-step procedure laid out there.
what does a alternator offer me over installing a 12 generator?
If you are going to use it regularly the alt. is the best way to go. It puts out more total amps. but mainly it puts out more at idle & slow speeds. The 1 wire is easy to hook up but the 3 wire system has better control. An alt. is more dependable & lasts much longer then a gen.
