1 members (sron48),
124
Mod | | | Forums66 Topics128,164 Posts1,056,966 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 105 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 105 | ok i guess i need some help on how i go about wiring an alternater into my truck. trying to get an order set off to get my parts for converting to 12 volts so i can get this thing on the road. | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | Blue, You didn't say if you already had an alternator, but I purchased a single wire alternater. One wire from alternater to Battery side of starter, done. Other alternaters can be converted to this.
Dennis | | | | | Joined: Oct 2009 Posts: 105 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 105 | no i don't have an alternator yet. trying to figure out if i want to go that route. dont' plan on running a lot of extra stuff. heck i don't even have a radio in it. my uncle had a 47 and he ran a radio but no extras just the heater/defrost and wipers not sure if the wipers were vacume or not and all on 6 volt. to me a generator is simple and i can rebuilt it. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I run a 63 amp alternator,with internal regulator.You can rebuild them ,very easy to do.If you are running a wide belt,you will need a different pulley.Speedway motors sell these pulleys. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | I bought Alternator and mount brackets for 58 235 from Patricks, it works like a charm and happy with it
Ganesh | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | The shop I got the alternator from had a wide pulley in stock | | |
