8 members (Oldpickupman, 41 chev, 51sub, Gdads51, Charles in CA, Nick in Manitou, TUTS 59, 1 invisible),
103
Mod | | | Forums66 Topics128,265 Posts1,058,360 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#59974 05/03/2006 1:23 AM | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | I have been fighting several parts on my 250 to make them fit the way they should. In particular, I have been fussing with a power steering pump\alternator alignment. I have tried the old 250 alternator to block mount and one I had from a 230. Neither works.
I wanted to keep the original motor from the truck as it was my grandpas, and sent it out to have it remanufactured. I was told the block had a minor crack and they replaced it with another.
Now I'm starting to wonder if some of my alignment problems may be related to a GM, but not Chevy product. The casting number on the block is 3894256. I can't find that number anywhere, including Santuccis book.
Can any of you help? | | |
#59975 05/03/2006 3:49 AM | Joined: Mar 2005 Posts: 75 Member | | Member Joined: Mar 2005 Posts: 75 | I looked in my inline power manual and did not see any number that starts with 389 for a block there were numbers for heads that started with 389 but did not match the rest of the number.
super250six | | |
#59976 05/03/2006 4:02 AM | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | I can't find that number either. It is marked GM. The stamping on the distributor pad is FO812EAH. That may mean something to someone. | | |
#59977 05/03/2006 4:21 AM | Joined: Mar 2006 Posts: 15 Junior Member | | Junior Member Joined: Mar 2006 Posts: 15 | I am going to be pulling the front clip off of my 67 this weekend. It will give me the ability to take some good detailed photos of the motor, a 250 if this would help you let me know and I will email you a few pictures. | | |
#59978 05/03/2006 2:39 PM | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | That may help indeed. particulalry the shape of the block mouning bracket for the alternator.
Thanks | | |
#59979 05/03/2006 7:39 PM | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | Could you double check your numbers?
There were some 389xxxx block casting numbers according to various online lists, a couple for 250's and one for a 194. The closest I've found to 3894256 is 8994256, but that's for a 292.
The EAH suffix is a mystery, too. I have an extensive list of Chevy engine ID suffixes, and EAH does not appear on any inline 6 for cars thru '79 (the last year for a car inline) and trucks thru '83 (the penultimate year for truck inlines, excluding the 292's that continued on in certain trucks--I don't have '84 info). The closest is TAH, which is for a 250 from '73, '74, '78, or '80.
Someone on a Camaro forum posted an engine number with the EAH suffix, but his was a small block (327), and that suffix didn't "officially exist" for 327's either, though there was an EA.
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
#59980 05/04/2006 2:36 AM | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | I double checked the ones on the block today. I believe I had one number wrong. After sanding the paint lightly on the numbers it appears they are 3994256. I'm going to lightly sand over the distributor pad in a few minutes.
Thanks for your help.
Checked it...definitely a EAH on the end. | | |
#59981 05/04/2006 6:42 PM | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 | Is it possible that your first number is an 8 and not a 3? 8's and 3's can be hard to tell apart in castings. 8994256 is the number for Chev 64-77 292 as Xram53 has indicated. Go to casting #'s on www.inliners.org to check for yourself.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
#59982 05/05/2006 12:13 AM | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | It's definitely not a 292. I WISH it was. | | |
