5 members (Bill Hanlon, 68ironhead, 48jim1ton, Hotrod Lincoln, Otto Skorzeny), 121 guests, and 2 robots.
Topics128,032
Posts1,055,517
Members48,425
#59974 05/03/2006 1:23 AM
I have been fighting several parts on my 250 to make them fit the way they should. In particular, I have been fussing with a power steering pump\alternator alignment. I have tried the old 250 alternator to block mount and one I had from a 230. Neither works.
I wanted to keep the original motor from the truck as it was my grandpas, and sent it out to have it remanufactured. I was told the block had a minor crack and they replaced it with another.
Now I'm starting to wonder if some of my alignment problems may be related to a GM, but not Chevy product. The casting number on the block is 3894256. I can't find that number anywhere, including Santuccis book.
Can any of you help?
#59975 05/03/2006 3:49 AM
I looked in my inline power manual and did not see any number that starts with 389 for a block there were numbers for heads that started with 389 but did not match the rest of the number.
super250six
#59976 05/03/2006 4:02 AM
I can't find that number either. It is marked GM. The stamping on the distributor pad is FO812EAH. That may mean something to someone.
#59977 05/03/2006 4:21 AM
Junior Member
Junior Member
I am going to be pulling the front clip off of my 67 this weekend. It will give me the ability to take some good detailed photos of the motor, a 250 if this would help you let me know and I will email you a few pictures.
#59978 05/03/2006 2:39 PM
That may help indeed. particulalry the shape of the block mouning bracket for the alternator.
#59979 05/03/2006 7:39 PM
X
X Offline
Could you double check your numbers?
There were some 389xxxx block casting numbers according to various online lists, a couple for 250's and one for a 194. The closest I've found to 3894256 is 8994256, but that's for a 292.
The EAH suffix is a mystery, too. I have an extensive list of Chevy engine ID suffixes, and EAH does not appear on any inline 6 for cars thru '79 (the last year for a car inline) and trucks thru '83 (the penultimate year for truck inlines, excluding the 292's that continued on in certain trucks--I don't have '84 info). The closest is TAH, which is for a 250 from '73, '74, '78, or '80.
Someone on a Camaro forum posted an engine number with the EAH suffix, but his was a small block (327), and that suffix didn't "officially exist" for 327's either, though there was an EA.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
#59980 05/04/2006 2:36 AM
I double checked the ones on the block today. I believe I had one number wrong. After sanding the paint lightly on the numbers it appears they are 3994256.
I'm going to lightly sand over the distributor pad in a few minutes.
Thanks for your help.
Checked it...definitely a EAH on the end.
#59981 05/04/2006 6:42 PM
Is it possible that your first number is an 8 and not a 3? 8's and 3's can be hard to tell apart in castings. 8994256 is the number for Chev 64-77 292 as Xram53 has indicated. Go to casting #'s on www.inliners.org to check for yourself.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
#59982 05/05/2006 12:13 AM
It's definitely not a 292. I WISH it was.
