3 members (Bill Hanlon, ShopRag, 1 invisible),
67
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,676 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#59969 05/02/2006 11:40 PM | Joined: Oct 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 275 | I was just wondering if it matters if a person mixes 5W30 and 10W30 does that just make 7.5W30. I needed to add some oil in my truck which I run 10W30 in but all I had in my shop was 5W30. Should I be concerned or just keep driving?
38 original 48 panel 59 stepside 46 in the back forty
#59970 05/03/2006 1:47 AM | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | It shouldn't matter, I do it all the time and my 77 Nova still has an intact original motor. It still has original timing chain and I've never adjusted the lifters or any thing .It nowhas 158,000 miles. | | |
#59971 05/03/2006 3:45 AM | Joined: Dec 2003 Posts: 510 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 510 | I agree with ya, Killer. There isn't all that much difference between 5w30and 10w30. I sure wouldn't lose any sleep over it.
On the other hand, I don't really care for multi-viscosity oils. They have always seemd to take on the characteristics of the lower viscosity rating more than the higher; that is, they seem to run a lot thinner and in my mind that's not a real good thing when it's hot. Cold weather is a different story, but since spring is just starting to sprung here, I prefer 30 or 40 weight oil. That's just one guy's opinion, tho. | | |
#59972 05/03/2006 3:12 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
#59973 05/03/2006 5:35 PM | Joined: Apr 2006 Posts: 236 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 236 | Polymers are added to an oil that meets the low temperature requirements to keep it from thinning out. This allows it to meet the high temperature requirements as well. A 5W30 oil is really a 5 weight oil with polymers added to make it behave like a 30W oil at high temperatures. Mixing a 5W30 with a 10W30 50:50 probably won't get you a "7.5W30" oil. Having said this, I wouldn't worry about the occasional mixing of 10W30 oil with 5W30. That second number is the most important one once the weather starts to warm up and you don't have to worry so much about the oil flowing like mollasses in winter. Since both oils behave like 30 weight at high temps, you should be fine, though with the addition of the 10W30 (which has fewer/different polymers than the 5W30), it might be slightly thiner at high temp. Say 28 weight oil??
58 Fleetside, 235, "The Old Buckin' Bronco"
