| | | Forums66 Topics128,291 Posts1,058,588 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#59933 05/02/2006 1:24 AM | Joined: Apr 2006 Posts: 1 Junior Member | | Junior Member Joined: Apr 2006 Posts: 1 | I am changing my brake master cylinder to a dual resivor and was wondering if I need to add a paportoning vale
Scott Glandorf
#59934 05/02/2006 3:15 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Not if you have the same style brakes and piston sizes front and back. If your brakes are stock, no valve is needed.
Fred 52 3600 69 C-10
#59935 05/03/2006 2:34 PM | Joined: Dec 2005 Posts: 112 Member | | Member Joined: Dec 2005 Posts: 112 | Not meaning to hijack here but what about a residual valve on a stock brake system?would that keep you from having to pump once to get your pedal to firm up,the master sits lower than the wheel cylinders. I have bled the brakes like crazy and all are adjusted right,or pretty close but still one pump before brakes,after that they work fine unless they are not used again for a few min. and then its one pump before brakes! I just rebuilt the wheel cylinders,master and replaced soft lines,no leaks.These are the good ole huck brakes so does this get any better or is this just what I have to live with useing stock brakes?
1949 Styleline Special 1972 K5 Blazer
#59936 05/04/2006 1:48 AM | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | Burnt: The original master should have a built-in residual valve at the outlet. Chevy called it a return valve. See the 48-51 shop manual page 5-4.
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
