3 members (rfs56trk, Dave1234, elhippie64), 103 guests, and 4 robots.
Topics128,203
Posts1,057,286
Members48,467
#59933 05/02/2006 1:24 AM
Junior Member
Junior Member
I am changing my brake master cylinder to a dual resivor and was wondering if I need to add a paportoning vale
Scott Glandorf
Not if you have the same style brakes and piston sizes front and back. If your brakes are stock, no valve is needed.
Fred
52 3600
69 C-10
Not meaning to hijack here but what about a residual valve on a stock brake system?would that keep you from having to pump once to get your pedal to firm up,the master sits lower than the wheel cylinders. I have bled the brakes like crazy and all are adjusted right,or pretty close but still one pump before brakes,after that they work fine unless they are not used again for a few min. and then its one pump before brakes! I just rebuilt the wheel cylinders,master and replaced soft lines,no leaks.These are the good ole huck brakes so does this get any better or is this just what I have to live with useing stock brakes?
1949 Styleline Special
1972 K5 Blazer
X
X Offline
Burnt:
The original master should have a built-in residual valve at the outlet. Chevy called it a return valve. See the 48-51 shop manual page 5-4.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
