2 members (Nick in Manitou, 1 invisible), 60 guests, and 1 robot.
Topics128,049
Posts1,055,679
#598608 12/06/2009 1:44 AM
I'm going to start wire brushing/removing all the loose rust on the underside of my cab etc. what is a good coating to put over those areas to prevent further damage?
If you're just removing the loose rust and wanting to cover it, a rust encapsulator is your best bet. It will stop the spread of corrosion and make s a good base/primer for painting down the road. Can get either brush on or spray on types that will do the job.
1956 GMC 370 dump " 'Tater "
1970 VW Volksrod "the Black Bomber"
2007 Chevy Avalanche
2020 Jeep Cherokee Trailhawk,
2005 Harley Davidson FLHTCUI
I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things.
But thats just MY opinion!
:P
Big Bolt Forum Co-moderator
I like the Zero Rust products. There is an article somewhere on the site here. Some guys like the Por-15, I have never used it. I can get the Zero Rust locally, but would have to order the Por-15 shipped to Canada.
1948 Chevy 2-Ton
Lordco can get you POR15 .... but Zero Rust is great thumbs_up
Yeah.. it doesn't have some of the nasties that Por 15 has and still seems pretty neat as a rust seal and prevention. I also like soaking my parts in molasses for two weeks to get rid of rust. It works! I found an article on this site that tells you all about it. I don't usually get a great price from Lordco, I wonder how much the Por 15 is there?
1948 Chevy 2-Ton
Riding in the Passing Lane
Rustoleum Rusty metal Primer.
1972 Chevy c10 Cheyenne Super
I've used a product called Rust-Mort that is supposed to chemically convert rust to "primer". I know it stops rust in its tracks, and turns it into a hard black substance. I wire-brush the remaining residue to remove loose flakes, and use rattle-can spray undercoater to prevent further rusting if no sheet metal repair is necessary.
