5 members (1955 1 Series, Oswald, Woodcmiami, Nick in Manitou, MRMEROTH11), 144 guests, and 1 robot.
Topics128,124
Posts1,056,334
Members48,439
Junior Member
Junior Member
Im in the process of putting on a new head gasket and one of my friends said I would need to buy new bolts because you can only torque them once?? Is this right or can they be reused?
Slade
If ain't broke Break it and fix it.
What engine are you putting a head on?
If it is a Stovebolt six, they were produced long before "stretch" or "torque to yield" bolts were invented, so don't worry about it.
If you have something that is relatively late-model, best to check a repair manual.
Junior Member
Junior Member
It is a 1953 pickup with a '56 chevy 235.
there were traces of water on the oil cap and when you take it off you canput your finger on the rocker arm and theres white snotty stuff that comes off of it. You think a blown head gasket is what is causing it?
Riding in the Passing Lane
More than likely. While the head is off check for cracks. You can use the same headbolts. We have nearly the same signature.
1972 Chevy c10 Cheyenne Super
Have you drained the oil from the pan? What did it look like? Is it possible that the traces of water you're finding are condensation? It's that time of year.
Keith
If it were easy they'd have grade schoolers doing it!
A good tip when reusing the head bolts is add white lithium grease under the head of the bolts.This will prevent any grabbing or friction resistents between the head bolt and the head.When the head bolt is torqued in place it is creating a clamp load.The clamp load is created when the bolt is stretched and then the bolt relaxes.Also a little oil on the threads will help, if they do not go into water.If they do you will need to use a sealer on the threads.
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
