6 members (jmoore, FAST55, 55shaker, LAROKE, Steveoreno, 1 invisible), 75 guests, and 3 robots.
Topics128,180
Posts1,057,165
Members48,465
Is the gas tank sending unit/float assembly the same in a '57 Suburban as in a pick up truck (you never know!).
If not, is there a company selling new ones for Suburban?
Thanks!
'57 Chevy Suburban; '70 Chevy Impala.
the gauge and resistance value is the same, the physical shape of the sender is different because the tank depth is different - I've never found anyone reproducing the panel sender - if you have a panel/burb [bad] original a good pickup sender can be modified to duplicate it ... worked for me
