2 members (1955 1 Series, 1 invisible),
131
Mod | | | Forums66 Topics128,181 Posts1,057,192 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | Is the gas tank sending unit/float assembly the same in a '57 Suburban as in a pick up truck (you never know!). If not, is there a company selling new ones for Suburban? Thanks!
'57 Chevy Suburban; '70 Chevy Impala.
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the gauge and resistance value is the same, the physical shape of the sender is different because the tank depth is different - I've never found anyone reproducing the panel sender - if you have a panel/burb [bad] original a good pickup sender can be modified to duplicate it ... worked for me
Bill | | |
