3 members (baldeagle, 2 invisible),
79
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,285 Posts1,058,535 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#59796 04/27/2006 11:57 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | How to read your vacuum gauge easily. What does it tell me?? Can I use this gauge to help diagnose what my engine is doing or NOT doing correctly. Will it help me find issues w/ valves & valve springs, timing, air cleaner, head and manifold leaks?? Take a look:: http://www.classictruckshop.com/clubs/earlyburbs/projects/vac/uum.htm
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#59797 04/29/2006 5:10 AM | Joined: Apr 2005 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 50 | The vacuum gauge is a very useful tool. The gauge will give a lot of information about the engine.
The web site you point out gives some good information on reading the gauge. It is best to spend time reading the gauge on a good running truck first, so you know what a good normal condition is at idle, wide open throttle etc. Once you get used to the gauge you can find problems quickly and easily using the chart.
I have a vacuum gauge installed on the dash of my '59 which I look at all the time. You can even improve gas milage if when you drive you try to keep the needle in the 15-20 in.hg. range. Pontiac installed vacuum gauges in some of their cars in the '60s.
The vacuum gauge is installed using a rubber hose that you hook up to a vacuum port on the intake manifold. There is usually a port that will be right in the middle of the intake that will give a good average reading of all cylinders. | | |
