0 members (),
108
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 49 New Guy | | New Guy Joined: Nov 2009 Posts: 49 | After bringing home my 46 chevy pickup 1/2 ton, I have decided I want to keep the truck original for the most part. I plan to use it as a daily driver to and from work, about 1/2 a mile each way. And restore to original down the road starting summer 2011. The only real alteration I would like to make is to lower it some, fairly modest drop. My main concerns are keeping it safe and keeping it as close to the original gear as possible/keeping the cost low (for original restoration). After a ton of reading, I am even more confused....dropped axles, drop spindles, remove leafs, mono leaf, axle flip, lowering blocks ect. Cheap lowering block kits or labor flipping the axle are right up my alley. The rear end seems obvious- remove some leafs plus lowering blocks if necessary. Or do an axle flip. Safety? Now the front end, I'm just not sure. What is the right way to go about trying to keep it as stock and cheap as possible? Oh, and safe too. I know lowering has been covered a million times and I have read as many threads as I could find but I just don't seem to be able to come to a final decision. I appreciate any help.Thanks.
Lowbow
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Go to Sid's www.droppedaxles.comThat is the best advice you will find period. Sid is on the HAMB often. You can even have your own axle dropped, then you know it will bolt right in. Sid will walk you thru everthing you need. There is no drop spindles available for your truck. Mono leafs will drop it more, however not required. I would invest in a disc brake swap to increase the braking Now if you had an AD, I would consider selling you an IFS kit.
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Lowbow, I have to agree with Scott, unfortunately 'cheaply' and 'safely' don't often go together.  I've never been a fan of lowering blocks on front axles,personally I would 'bite the bullet' and get a dropped axle. From what I've read about Sid is...he's the guy. There's a few bolters highly praise his products/knowledge. Good luck. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Nov 2009 Posts: 49 New Guy | | New Guy Joined: Nov 2009 Posts: 49 | Sounds good. Paying the extra $50 for the core might be a good idea too and keep the original axle on the shelf. The brake swap is a must, my old 57 with original brakes gave me a few minor heart attacks.
I saw a "slightly used" dropped axle from a 1950 1/2 ton for sale. The ad said that it will fit 47-54. A mistake I would think? Shouldn't it fit 41-55? Thanks for the advice.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Good luck Low whatever you decide. My suggestion is: add sway bars front and rear.
~Jim
| | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | exactly what Scott Danforth said.... you cant go wrong with one of Sid's dopped axles up front. check out my photbucket pics, i got one of his on my 57.
leonard | | |
