1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 67 | Anyone know of a good place to get this size in a mud/snow tread (reasonably)? I've tried the farm stores - and their all at least $200 a tire. Any one have a set? I need 6.
1937 Chevy (converted to 4x4) 1942 Chevy G506 1.5 ton 4x4 1958 Mack B model (on Chevy 1 ton 4x4 frame) 1969 Dodge Charger 1987 K30 Crewcab
| | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | I would go with re-treads on the rear. My local Bandag Dealer always had good prices on them.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Call Lucas Classic Tires @ 800-735-0166. They should have both NDT military and Hwy patterns. | | | | | Joined: Apr 2009 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 67 | Hey, thanks for the info guys - i'll check them out. Does anyone know if 8.25 x 20 will also fit my 1941 rims that currently have 7.50x20 on them?
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | The rims may be little wide for the rims but it probably won't hurt anything. How close are your rear duals now. You don't want them rubbing. Do you intend on hauling anything? | | | | | Joined: Apr 2009 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 67 | I found a set of 6 at a truck tire close out -but they are 8.25x20. Their is currently quite a bit of room between my duals with the 7.50's? Anyone ran 8.25's on their 6" rims?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I had 8.50's on my 46, worked OK as long as they were properly aired up - the fronts rubbed slightly at full lock but didn't cause any problems
Bill | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | New trucks had 6.5 wheels for 8:25's' but 6.0 should be OK if tubes are used and it is assumed that the tires you've found are tube type. | | | | | Joined: Apr 2009 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 67 | I assumed you could tube tires that are designed to be used as tubeless - is this not the case?( And yes I know what they say about assuming)
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Sure, you can run tubes in them and you should on those old wheels which sure were not made for tubeless.
That has me to wondering now just when tubeless truck tire first became available. Anyone know? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | That has me to wondering now just when tubeless truck tire first became available. Anyone know? My first guess is about 1956. The issue with tube and tubeless tires is the bead seat can have different angles, and if so they are not interchangeable. Also note that a multi piece rim needs a tube to hold any air. In general for truck tires the half sizes are tubeless, 17.5", 19.5", 22.5", and 24.5" for example. And tube type are usually whole inch sizes, 16", 17", 18", 20", 22", 24". This is the easy way to spot most tubeless rims/tires just by the size. Not many if any tubeless tires can be used on tube type rims, because of the obvious size difference (20" vs. 22.5") and because of the bead seat angle (I think 5* vs. 15*). Some more info here: http://www.stovebolt.com/techtips/wheels/ | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | My Dad was telling me about the '56 6500 that his Dad bought new. When they ordered it they paid extra for 8:25 X 20 tube tires. They were afraid of being out on the road and having to replace a tire and not being able to get a "new tubeless" tire. Don | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I've heard that a lot. In 56 Chevy big trucks came standard with 22.5" wheels and tires, yet most folks ordered the familiar tube type at extra cost.
My truck's got those wheels your Dad was afraid to order (well actually from a 56 4400)...
Grigg | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | If you are going to run 8.25 tires on a 6" rim, I would recommend using 7.50 tubes. Otherwise the tube will fold and will develop leaks in the creases in no time. Are the 8.25 radials. If so, you need to run a tube designed for radials. I doubt if 7.50 radial tubes are available. Tubeless truck tires really didn't become common until the late 1970's. I started switching my fleet from tube required to tubeless in the early 70's. My drivers carried an assortment of sheet metal screws because usually we couldn't find anyone to change tubeless tires. The drivers were instructed to pull out the nail and put cement on a sheet metal screw and screw it in the hole. That worked until we could get it patched from the inside. The reason I changed to tubeless was that almost half of our flats were caused by folded tubes and if drivers didn't notice a flat on a driver or trailer, the friction of the tube flopping around would catch fire. Tubeless tires eliminated all this and they are actually much easier to change. | | | | | Joined: Apr 2009 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 67 | Thanks for the adivce. Makes sense.
