2 members (baldeagle, Ponchogl), 98 guests, and 5 robots.
Topics128,014
Posts1,055,328
Members48,419
#59754 04/27/2006 3:16 PM
Do we ask brake questions here?
I am finishing my brake lines and was wondering about the little copper squash washers. On both the front and rear a bolt goes through either a bango connection or a brass block to connect the flexible line in the front and the hard line in the rear. Do you put one of these squash washers on both sides of the banjo connection or just as a washer between the bolt and the banjo connection ?
Bill Schickling
1940 1/2 ton, 1940 3/4 ton
My web page
#59755 04/27/2006 4:42 PM
I found one on each side when I restored my '48 truck
#59756 04/27/2006 6:35 PM
Banjo bolts take a crush washer on both sides.
#59757 04/27/2006 11:14 PM
I found them on both sides of my '41 3/4 ton, and replaced them on both sides. System works fine
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
#59758 04/28/2006 5:22 AM
I believe those little squash washers are a newer breed of brake line apparatus and were not in existence back in the 40's and 50's. Every "vintage" brake system I've ever worked on used crush washers.
Joe smile
#59759 04/29/2006 12:17 AM
if you don't use a crush washer (kinda like the washer found on spark plugs) crush washers can be made of alum or copper and have a rubber or neopreem inner.
and
you use a standard washer suited for this purpose (ie alum or copper plain washer) make sure the plain washer is flat on both sides. ie slid it down a very fine file on both sides w/ your finger just to see where or if it has any high spots. many of these washers (depending on there manufacturers) 'stamp' them from sheets of material and that can 'cup' the washer.
if you don't tighten them (and don't overtighten) they can leak.
Jim & Caroline
#59760 04/29/2006 12:30 AM
you can buy them at any parts store,,use on both sides...doc
#59761 04/29/2006 2:52 AM
Everyone,
Thanks.
Bill Schickling
My web page
