| | | Forums66 Topics128,068 Posts1,055,881 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | Anyone here put a Corvette LT1 motor in an old ride? I'm going to buy a nice used 92 LT1 with 6 speed manual tranny, computer, hydraulic clutch parts, for $1200. It will be going into my 69 chevy pickup. I know it will bolt right in for the most part. The questions I have are- where is the best and most cost effective place to buy a wiring harness? And, also, who is good at re-flashing the computer? And... Any info, pictures, links, etc. will be appreciated. I have a good idea of what I will have to do, but I'd like to know as much as possible before getting started. | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | use the stock harness if you have it. Why would you need to re-flash the computer, it should be a removable EPROM for a 92. Westers Garage, RAM, Hypertech, or Street and Performance can help.
If you really want to spend money on a wiring harness, then go with painless wiring.
| | | | | Joined: Mar 2008 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 60 | I put a 95 LT1 in my 34 ford. I used the stock wireing and removed the wires I didn't need. Get a GM shop manual for wireing information use the mass air flow sensor and you will not need to reprogram. I did get a hyper tech programer to correct my speedometer. If you run the same gear ratio and tire size as the doner you don't need to do this.This is OBD 1 so you can loose the converters | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | There is a book about swapping EFI motors that you might want to get. I've read it and though I've not yet done a swap, it made me much more confident that I can do the one I have planned. EFI Swaps BookIt does not cover every detail of every swap, but does cover all the concepts and offers lots of advice on how to approach a swap like this. Before you put down money on that car you need to think through the transmission crossmember. I don't know how you intend to deal with that problem, but a Corvette has a torque arm that extends from the transmission to the differential and does not have a conventional transmission crossmember. The Corvette manual transmission used before the 6-speed does not have provision for a mount pad. I don't know what that 6-speed looks like, or if it has a pad for a crossmember. I do know most people throw that 6-speed away rather than rebuild it.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | What is a removable EPROM? I've just seen everywhere that I'll have to re-flash, I don't know. I won't be getting the stock harness because the entire car harness is going to be sold to someone that had a fire. Believe it or not, I found the painless harness on jcwhitney for 600 bucks- 400 cheaper than competitors. Can that be right? I don't know about the trans. mount either. I have metal, saws, grinders, welders.. I think I can make something work!  | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | EPROM = Electronically Programmable Read Only Memory | | |
