7 members (52Carl, Wayne67vert, 53 green 1- ton, Otto Skorzeny, 78buckshot, DadsFirstPickup, greenie-reddy),
67
Mod | | | Forums66 Topics128,130 Posts1,056,713 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2002 Posts: 28 New Guy | | New Guy Joined: Aug 2002 Posts: 28 | Can anybody tell me what rearend will swap out for the original w/4:11 gear? I want to replace the entire rearend, not just gears. Someone suggested a stock F-150, but I need to know for sure. I would like to use a 3:55~as the little 235 in this truck sure whines at high rpms over about 55mph. Thanks for any help.
"If you're not living on the edge, you're taking up too much space. Life is short, eat desert first."
| | | | | Joined: Mar 2001 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 384 | Hi Jeff-- You will want to look at this site: Rear End Measurement web page  Blazer and camaro rear-ends are popular swaps. Most keep rear end ratios at 3.4 or greater. You will want to pay some attention to wheel bolt patterns. You don't say what is on your front but F o r d seems an unlikely candidate to match ur front. Gud luk.
Buzz'n Half Dozen
