| | | Forums66 Topics128,141 Posts1,056,485 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 39 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 39 | I neeed to replace the mounting bolts on the parking lights on my 51 GMC, they are a two sided with a threaded bolt that mounts the unit to the fender and a female end to mount the glass lense. Where can I source these ?
I am going nowhere fast and it's not taking me long to get there !!!!
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | I haven't seen repops of those. You might have to look for used or improvise something. You might be able to cut threads into some tubing. screw a machine screw in one side and cut the head off. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | That kind of bolt is used alot in building electical control panels so I would think You can get them from MacMaster Carr I don't know what they are called but if You search around MMC You should be able to find them .
Pete | | | | | Joined: Sep 2008 Posts: 39 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 39 |
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | If they are used in electrical panels, they would probably be in the Grainger catalog. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | MacMaster Carr is the guru of hardware stores , all hale to MMC,
Pete | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | They are called stand offs just looked at them on MMC they have all kinds so just type in stand offs and they come up .
Pete | | | | | Joined: Sep 2008 Posts: 39 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 39 | Thank everyone, I ened up TIG welding a new 10/24 bolt and reusing the female end for the lense and bezel.
