| | | Forums66 Topics128,049 Posts1,055,747 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 44 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 44 | I'm reassembling a 37 pickup that belonged to my Dad. I am painting the "splash" pans that surround the lower engine area. the exhaust and oil breather/overflow go down through these. they are currently black, but were repainted about 30 years ago. Is black the correct color? Would it have been a chassis black finish or some other finish. I'm also wondering about the engine color. The gray that's on it now (a recent repaint) is about the shade of a gray primer. I've got conflicting info that says this color is correct, and other opinions say it should be darker. I personally think it should be a darker gray. Does anybody know who has "the" correct paint for this? I have heard some restoration engine paint colors are not accurate. I appreciate your input. | | | | | Joined: Aug 2005 Posts: 277 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 277 | The "splash" pans on my 39 have the original black paint. Looks like a chassis or satin finish. | | | | | Joined: Jul 2008 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 176 | Yes, the engine paint should be quite dark. The splash pans on my 41 where the same almost gloss black as the frame. | | | | | Joined: Feb 2009 Posts: 44 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 44 | Thanks. Anybody have a good source for the engine paint in the correct color? | | | | | Joined: Jul 2008 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 176 | Filling station, Chev's of the 40's, and Bill Hirsch's new darker color. Not Jim Carter's or Hirsch's lighter gray. | | | | | Joined: Feb 2009 Posts: 44 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 44 | | | |
