9 members (GMCJammer51, Materman, Lightholder's Dad, Ridgeback, Brian Moore, tclederman, jupitor, treegrower, 1 invisible), 189 guests, and 2 robots.
Topics128,080
Posts1,055,952
Members48,430
#596939 11/30/2009 8:11 PM
Anyone know of a good place to get this size in a mud/snow tread (reasonably)? I've tried the farm stores - and their all at least $200 a tire. Any one have a set? I need 6.
1937 Chevy (converted to 4x4)
1942 Chevy G506 1.5 ton 4x4
1958 Mack B model (on Chevy 1 ton 4x4 frame)
1969 Dodge Charger
1987 K30 Crewcab
Bodyguy #596951 11/30/2009 8:47 PM
I would go with re-treads on the rear. My local Bandag Dealer always had good prices on them.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
Call Lucas Classic Tires @ 800-735-0166. They should have both NDT military and Hwy patterns.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
53moneypit #597121 12/01/2009 4:21 AM
Try these guys. They stock 7.50s and will make a little better deal on 6 of them. http://www.nebraskatire.com/truck/overstocks.htm
crenwelge #597138 12/01/2009 4:58 AM
Hey, thanks for the info guys - i'll check them out.
Does anyone know if 8.25 x 20 will also fit my 1941 rims that currently have 7.50x20 on them?
1969 Dodge Charger
1987 K30 Crewcab
Bodyguy #597301 12/01/2009 8:55 PM
The rims may be little wide for the rims but it probably won't hurt anything. How close are your rear duals now. You don't want them rubbing. Do you intend on hauling anything?
crenwelge #597456 12/02/2009 5:08 AM
I found a set of 6 at a truck tire close out -but they are 8.25x20. Their is currently quite a bit of room between my duals with the 7.50's? Anyone ran 8.25's on their 6" rims?
1969 Dodge Charger
1987 K30 Crewcab
Bodyguy #597458 12/02/2009 5:10 AM
I had 8.50's on my 46, worked OK as long as they were properly aired up - the fronts rubbed slightly at full lock but didn't cause any problems
Flxible #597523 12/02/2009 3:00 PM
New trucks had 6.5 wheels for 8:25's' but 6.0 should be OK if tubes are used and it is assumed that the tires you've found are tube type.
Dave
53moneypit #597609 12/02/2009 8:49 PM
I assumed you could tube tires that are designed to be used as tubeless - is this not the case?( And yes I know what they say about assuming)
1969 Dodge Charger
1987 K30 Crewcab
Bodyguy #597619 12/02/2009 9:41 PM
Sure, you can run tubes in them and you should on those old wheels which sure were not made for tubeless.
That has me to wondering now just when tubeless truck tire first became available. Anyone know?
Dave
53moneypit #597635 12/02/2009 10:04 PM
My first guess is about 1956.
The issue with tube and tubeless tires is the bead seat can have different angles, and if so they are not interchangeable.
Also note that a multi piece rim needs a tube to hold any air.
In general for truck tires the half sizes are tubeless, 17.5", 19.5", 22.5", and 24.5" for example. And tube type are usually whole inch sizes, 16", 17", 18", 20", 22", 24".
This is the easy way to spot most tubeless rims/tires just by the size.
Not many if any tubeless tires can be used on tube type rims, because of the obvious size difference (20" vs. 22.5") and because of the bead seat angle (I think 5* vs. 15*).
Some more info here: http://www.stovebolt.com/techtips/wheels/
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #597650 12/02/2009 10:36 PM
My Dad was telling me about the '56 6500 that his Dad bought new. When they ordered it they paid extra for 8:25 X 20 tube tires. They were afraid of being out on the road and having to replace a tire and not being able to get a "new tubeless" tire. Don
don stocker #597664 12/02/2009 11:31 PM
I've heard that a lot.
In 56 Chevy big trucks came standard with 22.5" wheels and tires, yet most folks ordered the familiar tube type at extra cost.
My truck's got those wheels your Dad was afraid to order (well actually from a 56 4400)...
Grigg
---All pictures---
Grigg #597819 12/03/2009 5:12 AM
If you are going to run 8.25 tires on a 6" rim, I would recommend using 7.50 tubes. Otherwise the tube will fold and will develop leaks in the creases in no time. Are the 8.25 radials. If so, you need to run a tube designed for radials. I doubt if 7.50 radial tubes are available. Tubeless truck tires really didn't become common until the late 1970's. I started switching my fleet from tube required to tubeless in the early 70's. My drivers carried an assortment of sheet metal screws because usually we couldn't find anyone to change tubeless tires. The drivers were instructed to pull out the nail and put cement on a sheet metal screw and screw it in the hole. That worked until we could get it patched from the inside. The reason I changed to tubeless was that almost half of our flats were caused by folded tubes and if drivers didn't notice a flat on a driver or trailer, the friction of the tube flopping around would catch fire. Tubeless tires eliminated all this and they are actually much easier to change.
crenwelge #598892 12/07/2009 4:12 AM
Thanks for the adivce. Makes sense.
1969 Dodge Charger
1987 K30 Crewcab
