1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#596821 11/30/2009 6:26 AM
I neeed to replace the mounting bolts on the parking lights on my 51 GMC, they are a two sided with a threaded bolt that mounts the unit to the fender and a female end to mount the glass lense. Where can I source these ?
I am going nowhere fast and it's not taking me long to get there !!!!
I haven't seen repops of those. You might have to look for used or improvise something. You might be able to cut threads into some tubing. screw a machine screw in one side and cut the head off.
That kind of bolt is used alot in building electical control panels so I would think You can get them from MacMaster Carr I don't know what they are called but if You search around MMC You should be able to find them .
Pete
THANKS
Thank you !!
If they are used in electrical panels, they would probably be in the Grainger catalog.
MacMaster Carr is the guru of hardware stores , all hale to MMC,
Pete
They are called stand offs just looked at them on MMC they have all kinds so just type in stand offs and they come up .
Pete
Thank everyone, I ened up TIG welding a new 10/24 bolt and reusing the female end for the lense and bezel.
