3 members (Bill Hanlon, baldeagle, Cosmo), 136 guests, and 3 robots.
Topics128,090
Posts1,056,371
Members48,442
#596676 11/29/2009 10:46 PM
I'm upgrading my 41 1/2 ton's front brakes to 51-59 bendix brakes. Do the 51 - 59 front wheel cylinders have to be installed as marked (right to right side and left to left side) or can i switch them to opposite sides? Installed as marked, the brake hoses have more tension than if i were to switch them (since the brake hose has to be screwed into the more forward part of wheel cylinder).
I can think of no reason why it would matter which side a wheel cylinder is on beyond how the hoses fit. If the hoses fit better one way than the other I'd install the wheel cylinders for best hose fit.
I'd look and see the location of the bleeder screw and make sure you can open and close it. Also make sure that the wheel cylinder "seats" on the machined surface so its tight and flat against the backing plate. I'd also caution having any pressure on the brake hoses when installed. I would think that having them pulling will lead to the inside collapsing and causing a whole bunch of other problems.
I did the change on my 39 and switched wheel cylinders for the better hose fit.
Thanks for the responses, I'll try switching them tonight.
