2 members (Peggy M, 59 fleet),
87
Mod | | | Forums66 Topics128,096 Posts1,056,489 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | on a rebuild, sometime back, posters talked about operating the oil pump with a drill in order to get oil throughout the system before starting the engine - how would the oil pump turn when it's geared to the cam, crank, pistons etc? | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | The gear is on the distributor. Without the dist. installed, the oil pump should spin freely. | | | | | Joined: Feb 2000 Posts: 5,226 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,226 | A old distributer cut off and gear missing works very well. If you don't have one to cut up, use a old screwdriver and run the drill slow. On a rebuilt V8, a 1/2" drive big drill will really work at 60PSI oil pressure.
Joe | | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | bingo! i forgot that the gear is on the dist and didn't look before asking. thanks | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i'm sure you know the gear is what the cam used to drive the dist. the tang on the bottom is what drives the oil pump. you might cut the shaft off a old dist that chucks in the drill motor pretty easy. i am no expert on anything, but i like to have my wife turn the engine while i run the drill motor that way the bearings get a good bath. i don't do it so much that it would interfear with the cam breakin in that would be a concern. good luck. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I took the gear off an old distributor ($10, used), which then allows the distributor to be installed into the block and into the oil pump, without engaging the camshaft gear. Then, it is an easy matter of using a hex socket-bit in a drill to turn the distributor post to prime the oil pump and run oil through the lubrication system.
| | | | | Joined: Feb 2004 Posts: 29,832 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,832 | I made up an aluminum bushing to fit into the distributor hole, with a 1/2" shaft through the center and a tang ground onto the end. A shaft collar sets the depth correctly to engage the oil pump, and I've ground a 3-sided flat on the top to keep the drill chuck from slipping as the load comes onto the pump. It's adjustable for either 6 cylinder or V-8 by moving the shaft collar up or down. Jerry
