Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (J Lucas, Sjm), 115 guests, and 1 robot.
Topics128,285
Posts1,058,534
Members48,490
#59631 04/25/2006 6:04 PM
Junior Member
Junior Member
i checked all electrical, fuel pump is working what more is there to do if i put gas in the carb it will turn on then die out like its not getting fuel but i put a new fuel pump in it yesterday and it seems to work is there anything im overlooking or is this just beyond me?
#59632 04/25/2006 10:51 PM
Could you have a cloged filter stuck float. What kind of rig do you have?
#59633 04/25/2006 11:24 PM
Ex Hall Monitor
Ex Hall Monitor
If you're sure it's a fuel supply problem, disconnect the fuel line from the carburetor and crank the engine. If gas squirts out of the line your problem is the carburetor. If not pull the line where it exits the fuel pump and crank the engine. If you get gas, the line from the pump to the carb is plugged. If you don't get gas pumping there & the pump is new I'd suspect the line from the tank to the pump. Good luck.
#59634 04/25/2006 11:30 PM
it looks like he has a 54 - 3100
Jim & Caroline
#59635 04/27/2006 5:17 AM
I had the same problem on mine recently and it was a kink just in front of the fuel tank... not sure how that happened since it was protected by the frame but oh well... kept me guessing for awhile... good luck
Boogity, Boogity, Boogity Let's go racin boys.
Drive fast, turn left. GO #20.
Real trucks where bowties.
#59636 04/27/2006 6:33 PM
same thng happened to me and it was the float level. float had a hole in it.
54 3100 w/62 235 "Yosemite Sam"
Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
