| | | Forums66 Topics128,169 Posts1,057,035 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#59631 04/25/2006 6:04 PM | Joined: Apr 2006 Posts: 18 Junior Member | | Junior Member Joined: Apr 2006 Posts: 18 | i checked all electrical, fuel pump is working what more is there to do if i put gas in the carb it will turn on then die out like its not getting fuel but i put a new fuel pump in it yesterday and it seems to work is there anything im overlooking or is this just beyond me? | | |
#59632 04/25/2006 10:51 PM | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | Could you have a cloged filter stuck float. What kind of rig do you have? | | |
#59633 04/25/2006 11:24 PM | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | If you're sure it's a fuel supply problem, disconnect the fuel line from the carburetor and crank the engine. If gas squirts out of the line your problem is the carburetor. If not pull the line where it exits the fuel pump and crank the engine. If you get gas, the line from the pump to the carb is plugged. If you don't get gas pumping there & the pump is new I'd suspect the line from the tank to the pump. Good luck.
#59634 04/25/2006 11:30 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | it looks like he has a 54 - 3100
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#59635 04/27/2006 5:17 AM | Joined: Aug 2005 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 81 | I had the same problem on mine recently and it was a kink just in front of the fuel tank... not sure how that happened since it was protected by the frame but oh well... kept me guessing for awhile... good luck
Boogity, Boogity, Boogity Let's go racin boys. Drive fast, turn left. GO #20.
Real trucks where bowties.
#59636 04/27/2006 6:33 PM | Joined: Oct 2003 Posts: 297 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 297 | same thng happened to me and it was the float level. float had a hole in it.
54 3100 w/62 235 "Yosemite Sam" Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
