0 members (), 116 guests, and 2 robots.
Topics128,105
Posts1,056,541
Members48,448
Apprentice
Apprentice
what tooling do you use ? i have a little 3 finger gear puller but the fingers are too thick. any help is appreciated!!thanks
t5stang91,
The cam gear is pressed on pretty darn tight. It is best to press if off with a shop press of some sort.
The crank gear is often merely slipped on by hand. I would try a couple of screwdrivers to pry with first...it might just slip off. If this doesn't work then a two finger puller would do the trick.
Stuart
If we are talking about a stovebolt here, the cam gear is removed in a press. The "crank gear" has two threaded holes if it is original. These are used with a puller.
1951 1 Ton Completed
Apprentice
Apprentice
yes a stovebolt.i am gonna take apart my '62 235 soon and i noticed on a old 216 i had that was junk it didn't come apart that easy but i was just wondering, didn't recall any holes in the crank gear but there may have been. thanks for the help.
My replacement gear on the crankshaft did not have holes. My machinist told me that if it doesn't have holes, just take a good stout chisel and give it a shot in a tooth notch near the keyway and it will crack the gear.
Fred,
I think all the crank gears I have encountered were steel. I might buy the cracking gear on a cast unit but find it hard to believe on a machined steel gear...but I am not a automotive machinist.
Stuart
Stuart,
I haven't had to try it out. He seemed to know his stuff and I guess if it works, it must be hardened steel. I haved removed bearing races on an axle using a similar technique. They shattered like glass.
I've always followed the shop manual instructions with no problems. These pages are from the 1955-2nd manual, but I believe the 62 would be the same.
page 6-22 page 6-23 page 6-32
As I recall, the crankshaft gear usually pulls off fairly easily.
Hoyt
The factory method of removing the crankshaft gear is great, if it is original. However, some of the replacement gears do not have the threaded holes for the puller.
The flat rate trick on the fiber timing gears was to break the gear away with a pry bar, and then use a chisel over the keyway to remove the metal hub. A set of 2-jaw puller jaws with a little custom grinding will hook into the thrust plate bolt access holes and pull the metal cam gears. Yes a crank gear will split, but it takes a sharp chisel and a BFH applied with some energy to make it happen. There's usually enough room behind the crank gear to accomodate a 3-jaw puller if there are no bolt holes in it. We always used a metal gear, either aluminum or cast iron, as a replacement for the cam gear, and heated it so it was a slip fit over the cam snout. Just make sure to get the timing marks aligned on the first try, as you won't get a second attempt!
Apprentice
Apprentice
ok thanks for the help. i will get to it in a couple weeks here , maybe sooner.
Huh! Aren't crank & cam gears keyed to the respective shafts? No chance for misalignment here. Aligning timing marks involves moving the cam to the desired position with the crank gear, and this can be done easily and/or repeatedly by merely pulling the cam out slightly and repositioning it.
I must have misunderstood the thrust of HRL's comment.
Stuart
