6 members (55shaker, Wickedbass, FAST55, rfs56trk, Hotrod Lincoln, Hanks custodian), 57 guests, and 3 robots.
Topics128,065
Posts1,055,868
Members48,428
#5962 04/20/2002 11:41 AM
I
I Offline
Okay, it runs, now need to get the trans going again. I have 3 & 4, but can't find 1,2, & R. Figure I need to play under the truck. What does the lever on the side of the shifter do? I don't have a 2 speed axle. The other truck does but not this one.
#5963 04/20/2002 11:46 AM
It's the reverse lock out .
You lift that wee lever with your pinkie and haul the stick across to your leg , then dump it down onto the seat . . . . . REVERSE . . . . .! grin
#5964 04/20/2002 2:29 PM
I
I Offline
Yeah i just figured that out, so now I have 3,4,R still no 1,2. The shifter must be rusty. It took alot to finally get reverse. I'm soaking it now.
I have driven it though!!!!!
