| | | Forums66 Topics128,087 Posts1,055,999 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#5962 04/20/2002 11:41 AM | Joined: Apr 2002 Posts: 50 Member | | Member Joined: Apr 2002 Posts: 50 | Okay, it runs, now need to get the trans going again. I have 3 & 4, but can't find 1,2, & R. Figure I need to play under the truck. What does the lever on the side of the shifter do? I don't have a 2 speed axle. The other truck does but not this one. | | |
#5963 04/20/2002 11:46 AM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | It's the reverse lock out . You lift that wee lever with your pinkie and haul the stick across to your leg , then dump it down onto the seat . . . . . REVERSE . . . . .!  | | | | | Joined: Apr 2002 Posts: 50 Member | | Member Joined: Apr 2002 Posts: 50 | Yeah i just figured that out, so now I have 3,4,R still no 1,2. The shifter must be rusty. It took alot to finally get reverse. I'm soaking it now.
I have driven it though!!!!! | | |
