Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (2-Ton, Shof, Charles in CA), 147 guests, and 3 robots.
Topics128,281
Posts1,058,487
Members48,490
#595446 11/25/2009 4:05 AM
Looking for a diagram or drawing of a (64)c-10 master cylinder. taking out the check valve and useing it for a hydraulic clutch. need to know what the insides look like
i have rebuilt the square and the round types from the sixties. the square one was what the 62 i used to have had.
This is a round master cylinder. Trying to convert it into a clutch master cylinder instead of a brake cylinder.
i don't know if you are close to oreillys but less than 2 years ago i got one of the square rebuilt ones for about $20. about double the cost of the rebuild kit. they have new ones that are priced higher but ask the clerk to look for a rebuilt one. unless of course you just want the fun of rebuilding, which can be good.
I don`t want to rebuild I need a drawing/diagram of the brake master cylinder.
I wonder if it'll move enough fluid to operate a clutch "slave" cylinder...?
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
Riding in the Passing Lane
Just put it together & leave out the check valve. The rest is the same.
1972 Chevy c10 Cheyenne Super
That is why I need a drawing or diagram to locate the check valve. That way I can see what I am doing. Without that I have no idea where it`s at
