6 members (J Lucas, papas52, fonz8261, JW51, Hotrod Lincoln, 1 invisible), 132 guests, and 2 robots.
Topics128,161
Posts1,056,956
Members48,458
I am looking for advice on what most people use to prep and paint the floor of their trucks. Doesn't need to be a show winner finish, but want it to be close to original without paying a lot. Do most sandblast the metal, or just rough it up, prime and repaint with rust-o-leum paint? Current condition is what you would normally see in a truck that is mid 50's and never been touched. But the floors are solid, the cab corners do need fixed, as with about all the 50's cabs. Thanks for the help! Niobrarafun
1956 Chevy 3100 Stepside Shortbox
More pix on Photobucket
If you're repairing the cab corners anyway and planning on painting I would suggest you check out Lizardskin. They have two products; one that is a sound deadner - supposedly kickass good. They also have a heat insulating product. I'd suggest you do that and THEN put a Rustoleum paint over it. That's what I'm planning.
Mine had a lot of surface rust on the back, firewall and ceiling..I wirebrushed it pretty good and then brushed it with flat black Chassis Saver....man a world of improvement........dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
Put a coat of roll on bedliner material on mine. Tough stuff and holds up well. Not a bad look either.
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
Just finished using POR 15 trunk/floor kit and it came out awesome. Check their website vs. Jim Carter for the best price. Use this code with Por web or phone for 10% savings HMN1209.
Hank
1951 restoration on website
http://www.hanklong.com
Just FYI, you can get POR15 on Epay from Eastwood, sometimes they have can & even full kits on sale at much less than most folks. The kit is a the best buy, the clean & prep chemicals are all there, & one small can of POR puts down a lot of coverage.
Simple prep work, and if you have any pinholes, or even screw holes you want to fill in just lay down a little fiberglass mat and paint over it like resin. Have known people to fix badly rusted floors that way too. Dries to a smooth glossy coat that is darned near bullet proof too.
I have it on my trans cover in the cab, diff cover, oil pan, and valve cover, and I'm planning on doing the whole interior under the dash & behind the seat/tank.
1956 GMC 370 dump " 'Tater "
1970 VW Volksrod "the Black Bomber"
2007 Chevy Avalanche
2020 Jeep Cherokee Trailhawk,
2005 Harley Davidson FLHTCUI
I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things.
But thats just MY opinion!
:P
Moderated by  ndkid275, Phak1
