3 members (tesa, baldeagle, pdlightning), 341 guests, and 3 robots.
Topics128,166
Posts1,057,092
Members48,463
Anyone know the length of the stock rocker arm retainer/valve cover studs?
Chuck
Chuck,
The Master Parts Catalog indicates 5-17/32"
Hoyt
Thank you hoyt. Glad I didn't try to make do with just a 5 1/2" stud.
Chuck
1/2" - - - - -.500
17/32"- - - - -.5031"
Is 30 thousandths of length actually going to make a difference? I doubt it! That's maybe two threads on the 3/8" X 24 nut!
1/2" - - - - -.500
Age must be sneaking up on you Jerry. 17/32" = .531". All the ones I have seen have a huge chamfer on the end so a 5 1/2" long one with a modest chamfer could potentially have more threads than original. The threads on the head side are coarse and fine on the top. Most aluminum covers will require them to be chopped shorter if using acorn nuts.
You Tube
