I do not know if this is the place to put this but here goes.
I mention here that I was building one adjustable height body cart so anyone with a bad back could work on the floor of their truck without having to bend to far over when working on it.
Materials list will be as follows.
20'11/2" x 11/2" x 1/8" SQ. wall tubing
4' 2" x 2" x 3/16" SQ. wall tubing
1' 3" or 4" channel cut 3" long
4 pnuematic 8" swivel casters with slime in the tubes Harbor Freight item.
16" of 4" x 4" flat 1/4" would be fine althought I has some 3/8" scrape that I made use of.
12" 3" x 3" flat for gussets
4 9/16" or 5/8" grade 8 bolts for pins 4" long with threads cut off.
Rust Mort if metal was rusty.
primer & Paint.
I used left over metal I had to cut the cost when I could.
Cut main 2x2's 12" long
Cut risers 11/2x11/2's 18" long
I also bolted flat pices to cab floor supports 3/16" x 11/2" one on each corner so when you move the cab you have less chance of it falling off the channels. one hole is 1/4" the other is 5/8" slid over the pins.
If you were going to use this for different trucks I would make the main frame adjustable too by adding 11/4" x 11/4" tubing inside the 11/2" tubing and using 1/2" bolt and nut combo to tighten it down.
NOTE on the 60's trucks the cab floor supports are not equal with 9" differental front to back.
You can click on the link below to see pictures too.
http://s892.photobucket.com/albums/ac130/62Blue2/
If you have any questions PM me.
62Blue
Don
62Blue
62Chevy in progress
You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
