4 members (Gdads51, Hanks custodian, MickeyP, homer52), 114 guests, and 6 robots.
Topics128,089
Posts1,056,137
Members48,435
#595357 11/25/2009 12:42 AM
A while ago I was looking at my 3804 parts truck and realized four of the five wheels that came with it are regular old one piece wheels and one was a traditional three piece wheel. The tires appear to be either 700x18's or 750x18's. Are these from the factory or something put on later. They look to be original. ohwell
Bruce
My Trucks
Stuff I Collect
Do you have pictures of the wheels posted anywhere?
The resto pack shows only one 18 inch wheel RPO number and set of specs. http://chevy.oldcarmanualproject.com/chevyresto/54159.htm
My father gave me a set of tubeless 8 lug rims that he said came from a later model Chevy truck. Maybe that's what you have?
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
Here is a non split and here is the three piece.
Bruce
My Trucks
Stuff I Collect
Can you look a little harder at the tires for size? I didn't think GM ever used an 18 except in a dual application. I'm not speaking from certain knowledge, just what I've seen...
I expected to see dually type wheels.
OK, I went down to the barn, it's dark and I got kinda scared but I found out they are 17" rims. Both 700x17's and 750x17's.
Bruce
My Trucks
Stuff I Collect
I'm pretty sure mine are 17" as well.
David Colter
Well at least I'm not confused about the 18 inch wheels any more. However, I don't think we're any closer to answering your question.
I don't know much about 17 inch wheels, including when they were offered or what tire options were available. You might try digging through the restoration pack pages to see what was offered when and that might get you down the path to an answer.
If no one comes along with more knowledge!
17" multi piece rims are normal and original on AD single wheel 1 tons.
I've not seen an old 17" tubeless wheel. (not to be confused with the new tubeless 17" wheels on newer cars and trucks)
I expect those wheels you have that appear to be tubeless in fact are, but are really 17.5" wheels. They are somewhat desirable, I've seen them sell and even sold some for more than I thought they were worth.
I prefer 19.5" wheels though, they are tubeless too and look about the right size on the 1 tons.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
So what is the real objective here? Identify the wheels and tires you have or determine what you want to put on this or another truck?
No, I'm not putting them on anything I have right now. It all started when I was taking a break while parting the truck out. I was looking at the them and noticed they were not multi piece wheels. Then I started wondering if these came from the factory as an accessory. I guess I'm wondering if they were original to the truck?
Bruce
My Trucks
Stuff I Collect
For 1954 the restoration pack shows only tube type tires available on 17 inch wheels for a single wheel 1-ton, so I'd conclude they are not original for an AD truck.
But I'd sure not be surprised if somewhere along the line someone upgraded.
My question is still:
Are they really 17" wheels (I doubt it) or are they actually 17.5" wheels.
Either way one piece wheels were not factory on AD 1 ton trucks.
Grigg
---All pictures---
The 3 piece semi drop center wheel was the common wheel used on Chev and GMC 1 tons and an option on 3/4 ton GMC. I think Ford used a 17" drop center (one piece) wheel that used 17" tube required tires at one time. Ford and GM used the same 8 hole bolt pattern. The center hole on a Ford was a little larger than GM. A Ford wheel will fit a GM but a GM will not fit a Ford. It could be a Ford wheel. It was common to use what you could make fit in the time this vehicle was still in use.
Originally Posted by crenwelge
..I think Ford used a 17" drop center (one piece) wheel that used 17" tube required tires at one time.
Interesting to learn, I'll keep an eye out for them just out of couriosity.
I do know Ford used 17.5" tubeless wheels too, I had dual ones on a 61 F350, and there's an early 60's pickup near me with single 17.5" wheels, but both were/are 6 lug.
Grigg
---All pictures---
Sounds to me like you got a little lucky. It could be easier to find tires and someone to mount them.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
Apprentice
Apprentice
We have a 1970 c-30 chevy drill team truck that has from the factory 18"wheels on split rims.I do not know what the [roblem with these rims are.We are pushing 789hp to the wheels and stop these trucks quicker and faster in 500 feet than a new z06.Go to youtube and look up piston knockers drill team and watch the vids with a 71'chevy c-30.tell me what you think of us new yorkers after that.
What tires are you running? Where do you get them?
From my standpoint tire availability is the biggest challenge with the 18 inch factory wheels.
Apprentice
Apprentice
We are running on the one truck 18's.the tires came from.let me think here for a minute universal vintage tire. they sell the tires(18") and tubes and the flaps.the tires are rather skinny and I would like to see something taller and wider.but good tires.
Moderated by  Dusty53
