| | | Forums66 Topics128,154 Posts1,056,863 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 227 'Bolter | | 'Bolter Joined: May 2005 Posts: 227 | I just rebuilt my 1960 Chevy C10 Master cylinder with the brake and clutch. The rebuild kit is the same for both sides.
I looked in the 1960 Shop manual on page 11-5 for help rebuilding the master. I noticed the brake side used all the parts where the clutch did not use the end rubber ring behind the return spring, nor does it use the return spring end.
Is this right?
1960 Chevy Apache (C10) 1965 Chevy C30 Dump Truck 1966 Chevy C30 Tow Truck | | | | | Joined: May 2005 Posts: 227 'Bolter | | 'Bolter Joined: May 2005 Posts: 227 | If you look at the cross section of the clutch, it also shows these parts as missing.
I am still troubleshooting my issue and want to eliminate this as a possibility.
Thanks.. Russ
1960 Chevy Apache (C10) 1965 Chevy C30 Dump Truck 1966 Chevy C30 Tow Truck | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The brake MC uses a check valve at the rear end. The clutch MC does not. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2005 Posts: 227 'Bolter | | 'Bolter Joined: May 2005 Posts: 227 | Wrenchbender...
That is the name of it... a check valve.
When I rebuilt the MC, both the cluth and brake had one installed. I wonder if that causes any problems. I bench bled the MC and now have to bleed it on the truck. Then I will know if I fixed my clutch problem.
Thanks.. Russ
