1 members (Jon G), 136 guests, and 1 robot.
Topics128,124
Posts1,056,334
Members48,439
#594981 11/23/2009 11:21 PM
I have a '56 3600 with rear duals.
It had 8.00x17,5 bias tires.
will the wider profile of 8Rx17.5 rub with the stock wheel offset?
Anybody have experence here?
I would question whether your bias ply type wheels will mount radials. Have you asked your tire shop?
I have no experience with the 3/4-ton dually trucks aside from seeing one or two and being surprised they were built.
If you already have 17.5" wheels likely it'll work.
Check with your tire shop before buying the tires.
I too am surprised about 3/4 ton dual wheel trucks, is your setup original?
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
I can't speak to this specific truck, but duals were an option on a Task Force 3/4-ton. I researched it up after seeing one at a swap meet a while back.
I assume that it is origional,dual rears, 9leaf rear springs and seperate overloads
