4 members (55shaker, IHPWR, Otto Skorzeny, 1 invisible), 76 guests, and 2 robots.
Topics128,026
Posts1,055,403
Members48,422
#594937 11/23/2009 7:59 PM
I just want to clarify checking gas gauges. I have 3 gas gauges for my truck (38 GMC) I want to make sure the one I use is good. So with an ohm meter I put one probe on each post and should have about 30 ohms correct, or should it read something else. Thanks in advance
1938 Gmc 1/2 ton
Assuming it is a 30 ohm unit, that is correct for one end of travel. It should taper off to zero ohms at the other end of travel.
Later gauges were 30 ohms. I'm not sure about yours.
Cletis described the test for a sender but you're asking about bench-testing the guage itself, right? Best way to check the guage is to hook the hot side of the guage to the pos. side of a 6V battery and the other side of the guage to a known good sender. Then connect the guage case and the sender ground post to the neg side of the battery. Move the arm up to full, then down to empty, the guage should follow.
Yep, I mis-read it.
Just to add clarification (maybe) for sender/gauge ohm ranges:
0-30 ohms for years up to the mid 1960s (for GM).
0-90 ohms for newer gauges/senders ( maybe 1965 and newer GM ).
Tim
