| | | Forums66 Topics128,037 Posts1,055,466 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 5 New Guy | | New Guy Joined: Nov 2009 Posts: 5 | Hi I have what I beleve to be a 1933 Chevy 1/2 ton truck frame. On the front and rear springs have pins that look like 5/8 threds on the pin with tappers on both sides with a grease fitting. Most shackle pins I have sean are smoth and press in theas screw in to the spring hanger from the frame. Does anyone reproduce the pin? All of them apear to be about half worn out.Any help will be welcome THANKS | | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | | | | | | Joined: Aug 2005 Posts: 277 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 277 | They are available but I have had difficulty with the replacements. They lack the proper taper were the pin fits in the shackle. | | | | | | OLTrucks Unregistered | | OLTrucks Unregistered | Flagg has discontinued many of the older part numbers (that we use) these last couple of years. So when ordering from your vendor ask where they are made (might be the answer to that low price) | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | I just bought a pair of shackles for my 54, they at least have those. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Those are the threaded pins and they used them for many years. I think I got mine from JC and the shackles fit the pins just fine. One of the suppliers that I also used is Espoe, I think they are called. They have some of the odd suspension parts too. | | |
