8 members (TUTS 59, Peggy M, 3B, J Lucas, David Bush, Southerntruck, msmall, Tyler Watts), 138 guests, and 4 robots.
Topics128,065
Posts1,055,863
Members48,428
#593988 11/20/2009 3:43 AM
k10
Offline
Who can tell me the setup of the deluxe horn ring (p/n 763178) for the 60-65 trucks? The stock wheel has a brass cup that is too deep to use with the deluxe steering wheel. Is a cup used at all, or does the plastic ring go against the wheel by itself. I haven't found any diagrams of the setup. I have looked in the master parts books, the service manuals and the assembly manual-no dice. If someone has an accessory installation manual hanging around.............? Thanks The deluxe wheel p/n is 766133.
k10 #594751 11/23/2009 2:19 AM
k10
Sorry I cannot help you with your question. Think of this as a bump.
I would ask you if you could tell me the diameter of your deluxe wheel.
k10
Offline
It is the same size as the standard wheel.
It looks the same as this one.
http://67-72chevytrucks.com/vboard/attachment.php?attachmentid=421201&stc=1&d=1232056330
