5 members (TUTS 59, ‘37ChevyPU, Cosmo, 78buckshot, Ponchogl), 107 guests, and 2 robots.
Topics128,050
Posts1,055,674
#59469 04/21/2006 4:09 PM
Should I expect to have to retune my 235 after I install a PCV valve. I have it installed and the engine seems to run fine (at least in the garage). I haven't had a chance to give it a road test yet.
Any comments or suggestions are welcome.
George
#59470 04/21/2006 10:31 PM
Riding in the Passing Lane
You should readjust the idle mixture. The cruising & power systems will probably be OK. You will know after a road test.
1972 Chevy c10 Cheyenne Super
#59471 04/22/2006 10:21 PM
46,
Wrenchbender is spot on. When I installed a pcv in my 41 I just had to lean out the idle mixture a little. Runs great.
Cheers
Bob
#59472 04/23/2006 1:45 AM
Depends on your valve and how much manifold vacuum drop it causes at idle.
I found the Deutsch PCV125 had the lowest drop of only 3" at idle, but still enough suction to excavate the crankcase gases.
You hardly have to adjust your carbs at all with this valve.
Also stays more open at high rpm and cruising.
Vacuum wiper motors work also better.
The pcv valves recommended in the new books seem too tight for the 235.
They lose almost all manifold vacuum already at idle and start shutting off too soon at part throttle.
On the road every day...
1952 Truck - 235
1948 Coupe - 261
#59473 04/24/2006 4:06 PM
Thanks guys. I leaned out the carbs a little this weekend. Seems to run great.
George
