3 members (TUTS 59, Oswald, Otto Skorzeny), 113 guests, and 1 robot.
Topics128,034
Posts1,055,548
Members48,425
#594048 11/20/2009 1:06 PM
I just installed cab lights on my 64, C30. As an electrical "dummy", I'm not sure if I should wire them through a relay, or just patch them into an existing wire under the dash that feeds the lights. There are five of them, and they are not LED, so I am not sure if the draw will require a relay or not. I want them to be on when both the parking lights, or the headlights are activated. Thanks guys!
I would use a relay and feed the control circuit from the park lights. Then a fused power supply to the relay for the lights. Then you dont have to worry about extra current draw through the light switch.
Do your park lights burn when the headlights are on?
If so, this should work. If not, I'm not sure, cause they would only light when the park lights were lit. You could add a 2nd relay controlled by the headlights if needed. Then they would light if either were on.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
The previous answer might be a bit complicated, if you end up needing 2 relays.
A simpler place to get the electricity is from the dashboard lights, thoses are on whether with parking lights or headlights: then you will need a relay, the dashboard lights circuit is usually pretty light gauge, a relay would be safer.
'57 Chevy Suburban; '70 Chevy Impala.
The parking lights? The headlights? The dashboard lights? Why not the tail light circuit? They are on with either park lights or headlights. And you probably don't need a relay but it wouldn't hurt anything if you use one.
Cletis is rignt, use the tail light circuit to acheive your goal. Matter of fact, that's how they are set up on my '71 and it works great that way. I don't have a relay, but those are never a bad idea.
1963 Chevy C20 Longbed Stepside
1978 Chevy K30 Custom Deluxe
Riding in the Passing Lane
I wire mine to the tail lights. You don't need a relay as they don't pull very much curent. I do run them through there own fuse. About 5 amp. That way if something would short out you would not lose your tail lights also.
1972 Chevy c10 Cheyenne Super
Well I think taillights it is! Thanks guys, I can always count on expert advise here on the bolt!
