2 members (fonz8261, TrknGMC), 226 guests, and 4 robots.
Topics128,074
Posts1,055,999
Members48,433
#543798 06/05/2009 12:17 PM
I am getting ready to instal the alloy cam gear and thrust plate on a new comp cams cam I kow the plate goes on first and to heat the gear at 200 deg. in water for 15 min. but I do not know how far to press the gear on I would guess flush but I hate to guessand I know I do not want to bind up the thrust plate between the gear and cam any help would be great
now thats a answer! thanks
I have a related questions to this one. I have the service manual for the 1954 truck and I was using it while rebuilding the engine. The line that says to "Install camshaft thrust plate to block screws and tighten them securely" doesn't say how much torque to use. After installing my cam, it spun freely in the bearings, but once I tightened the screws down on the thrust plate, it gets very difficult to turn the camshaft and there sounds like some metal drag coming from between the thrust plate and camshaft. Is this acceptable? This is my first time rebuilding an engine and this is pretty much my first step in the process since getting the parts back from the machine shop. Already feel in over my head.
MM9616B #594709 11/22/2009 11:47 PM
Get a shop manual for Your truck and keep it on the work bench while Your building the truck it will give You all the specs on Your engine and all the info on Your truck .
No the cam should not get hard to turn after You install the plate there is a spec for setting the plate
There are shop manuals on line You could look thru I don't where to find them but somone here will give You the info.
Pete
