| | | Forums66 Topics128,075 Posts1,055,918 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#59448 04/21/2006 1:53 AM | Joined: Sep 2004 Posts: 46 Member | | Member Joined: Sep 2004 Posts: 46 | Today the local auto salvage called and said they located a '72 3/4 ton 4:10 pumpkin for me. It will be going into my 48 1-ton..what can I expect in speed & performance once installed? Thanks, Cliff | | |
#59449 04/21/2006 3:09 AM | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | what size tires are you running? how many rpm can you stand to turn? Is it s 216 or a 235? | | |
#59450 04/21/2006 3:18 AM | Joined: Sep 2004 Posts: 46 Member | | Member Joined: Sep 2004 Posts: 46 | The engine is a fresh rebuild '54 235, and the tires will be stock 17 inch. As for rpms, I really don't know. | | |
#59451 04/21/2006 2:10 PM | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | Check out this site: http://www.f-body.org/gears/ You will need to know the height of your tires. I usually set my redline at 3500 to figure the max speed I could possible tolerate in any given gear. I think you could tolerate 70 for short periods, assuming your brakes are up to the stopping task. Normal around town speeds of 45-55 should become very pleasurable instead of right at the limit of tolerable and your mileage should really improve. Again, I urge you to make sure your brakes can stop you at higher than originally expected speeds. | | |
#59452 04/25/2006 11:29 AM | | Anonymous Unregistered | | Anonymous Unregistered | hey lcliffn, i did that swap 3 years ago and it made a great differance in driving. i'm runnung 750 x 17s and changing from a 514 to a 410 rear end will also improve your gas milage plus 70mph.
tony'n weatherford | | |
#59453 04/25/2006 12:13 PM | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | you can expect slow and alot of rpm,s,,,stay off the freeway...doc | | |
