0 members (), 79 guests, and 1 robot.
Topics128,049
Posts1,055,740
#59448 04/21/2006 1:53 AM
Today the local auto salvage called and said they
located a '72 3/4 ton 4:10 pumpkin for me. It will be going into my 48 1-ton..what can I expect in speed & performance once installed? Thanks, Cliff
#59449 04/21/2006 3:09 AM
what size tires are you running? how many rpm can you stand to turn? Is it s 216 or a 235?
#59450 04/21/2006 3:18 AM
The engine is a fresh rebuild '54 235, and the tires will be stock 17 inch. As for rpms, I really don't know.
#59451 04/21/2006 2:10 PM
Check out this site:
http://www.f-body.org/gears/
You will need to know the height of your tires. I usually set my redline at 3500 to figure the max speed I could possible tolerate in any given gear.
I think you could tolerate 70 for short periods, assuming your brakes are up to the stopping task.
Normal around town speeds of 45-55 should become very pleasurable instead of right at the limit of tolerable and your mileage should really improve.
Again, I urge you to make sure your brakes can stop you at higher than originally expected speeds.
#59452 04/25/2006 11:29 AM
Anonymous
Unregistered
Anonymous
Unregistered
hey lcliffn, i did that swap 3 years ago and it made a great differance in driving. i'm runnung
750 x 17s and changing from a 514 to a 410 rear end will also improve your gas milage plus 70mph.
tony'n weatherford
#59453 04/25/2006 12:13 PM
you can expect slow and alot of rpm,s,,,stay off the freeway...doc
