| | | Forums66 Topics128,087 Posts1,055,974 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | We're About to start removing the seat frame from a 52 1/2 ton Chevy truck to install buckets. Last time i looked it appeard to be welded in. Whats involved? Thanks.
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | If you are talking about the enclosure right against the cab floor (toolbox, seat support frame) then yes it is spot welded along the lip where it meats the floor. People remove them all the time just start cutting or grinding the spotwelds. You will want to and need to remove the fuel tank for access and safety. | | |
